Moisture on floor mat and Jeep sitting in garage
LuvmyJeep
Vancouver
Have you ever had moisture on your plastic floor mats while Jeep sitting in garage for a couple of weeks.
Lots of rain here in Vancouver……no moisture on passenger side.
Heater core...but not passenger side.
Condensation? Throw a dehumidifier if there and shut the doors.
Yes I have. 0 breathability plastic floor mats, jeep sat in barn when not used. I figured it was condensation between the carpet and mat from when It was driven and the hot cold cycles.
I’m having a similar issue but under the trunk carpet. I don’t see any trails of water leaking but the carpet is always wet especially after a rain. I have a trunk tray and there’s no water on top of that’s.
Need to figure out where it’s coming from and will try to use a hose when it’s not freezing outside.
Do you park in an area with a grade ?
Years ago I had a similar problem and determined the parking on a grade caused the water to move from the leaking area to a lower area.
Yes front is higher than the back but nothing is wet except the back half of the trunk.
I check the sides and nothing either.
