I'm impressed you were able to get the washer bottle back in there!
We can't see the bottom end that was heated with a torch and reshaped to fit it's new home.
Can you link me to where you describe your intake? That setup might fit below my Coilover cross over tube. You draw from headlight area?
Ya I havnt heard great things about it but hadn’t given me an issue besides having to modify it right away to fit the battery they advertised it with. I’m really hoping flux can deliver bc my stock highlined fenders are completely split inner from outer.
I have the Nemesis fenders and have generally been pretty happy with them.
They come with brackets to re-locate everything under the hood with the exception of the earlier charcoal canister. Mine is back in the rear wheel well so I’m not sure what their solution is for the under the hood unit on the earlier models.
It comes with brackets to mount everything else though, vacuum canister, cruise servo, evap solenoid, factory washer reservoir, horn, etc. The early style required the use of an Optima battery but they have since redesigned the battery box to fit any group 34 battery. I’d recommend calling or emailing them first though if you are buying to make sure you’re getting the new battery box.
They offer a more complete solution than others I’ve seen.
Is Nemesis still in business?
Is Nemesis still in business?i e never heard of the (aluminum overlay)looks pretty cool.
They were as of a couple of weeks ago when I talked to Rob about the new battery tray.
I’ll try again later
I have 3 buddys that have the nicest bamboo printers and even sell a lot of prints. Almost always do I ask for the same print with a quantity of 3 or 4 bc it always breaks. Rc car stuff, gun stuff, car stuff, around the house stuff.
The only thing that hasn’t broken is an insert for my center console tha was intended to put a sub in the main compartment and have storage from the insert. It’s about 1/4inch thick tpu. So far tpu is the only thing I’ve seen last.
What filaments are you seeing breakage from? I would be interested if its ABS, NYLON, PLA, ETC.
Any recommendations for fenders that wouldn’t require cutting?
This thread is about highline fenders. My recommendation is away from any fender that is a highline.
Noted. Thanks. Still trying to navigate the forums here.
PS go Alum not matter what the steel ones are HEAVEY
X2. My steel highlines are 32 lbs each. Stock fenders weigh 18 lbs. I want to say genrights hover around 9-10 lbs
