So it begins.
We are converting 40 City TJs to all EV.
Our first one is a 2003 Jeep TJ. About 2/3 done but wanted to share were we are.
So much has been done already, I know I should have posted more and more and more but, it's hard when the team is VERY small.
I'll jump in where we are right now.
The Back Battery Box is in and fully finished. It looks like this when out of the Jeep:
It's designed to fit into the exact location of the stock gas tank. There are only three designs we do, CJ, YJ and not the TJ version.
This is mounted using existing bumper bolt locations plus 4 added 5/16" RivNuts into the existing gas tank cross member under the Jeep.
From the back, this is all you'd see:
At the moment, we're working on the Front Battery Box and the Tech Box.
The Tech Box is divided into two parts; the HV-JB and the LV-JB.
NOTES:
- HV-JB = High Voltage Junction Box (144v nominal)
- LV-JB = Low Voltage (12v) Junction Box
Here's a snap with the fender on to work out clearances and stuff:
The cardboard part is the Tech Box and the thing next to it is the Front Battery Box.
My design process is pretty straight forward;
- Cardboard and blue painters tape
- Plywood (if necessary or I have to build stuff that attaches to it)
- Aluminum
I'm under the gun with the City so I'm moving as fast as I can to get this first one done and out the door.
Okay, I'm sure this is enough to wet your appetite, ask anything but if it's insulting, I've learned, it's better to just ignore.
- Patrick
NOTES:
- Aluminum
- Patrick
