TTB is still IFS. But TTB are an easy way to get suspension travel. On my design with a 12in shock, it will end up with nearly 18-20in of wheel travel. Compared to a double A-arm, its also way simpler. It has drawbacks compared to an A-arm setup, like camber cannot be controlled or tuned beyond where it is initially set.
True.
I guess my mental block was the center u-joint I remember in the Bronco. I'd assume you'd end up with a crazy angle there, but I guess you use a super high angle CV?
