Post your side shot videos going over speed bumps at 15mph
I hit a speed bump tonight at 15 mph I think that’s the right speed, I don’t really want to hit it any harder lol. Need to dial the compression down on the rears. I could tell the rear is stiffer than front. But I think I might want rear stiffer than front so there isn’t a bunch of weight shift from the from the front impact onto the rear.
Put DSCs up front to make both ends work together and you can hit it harder.
I vote TTB
I vote TTB
I've read, but not confirmed myself, that TTBs are the best choice for high speed desert driving (whoops, etc). However, the design would be a tradeoff vs solid axles for crawling, correct? TTBs have less, lopsided articulation, tricky to set camber over about 2" of lift, and less ground clearance.
Reactions: speeding_infraction
Damn, throwback to my Full Size Bronco.
It's kind of halfway to IFS. Although $$$$ I'm sure high-end IFS setups have gotten better than TTB in the rocks, and they are definitely superior in the go fast.
How about this...
As it is I would say that shows very little of how damped your suspension is? It’s slow speed articulating. Now if you remake that video hitting it at 15mph straight on, that would do!!
Reactions: hosejockey61
Its some dollars to do it right, but its fun watching the $500 TTB Fords run through the wringer at Silver Lake. I am slowly working on a design for a TTB in a TJ/LJ. Its purely CAD drawings now, but the models get more and more serious eventually it will happen and its feasible. There are a few TTB Jeeps out there.
  • Love
Reactions: Negreac
Sweet!
Curious, is there a specific driving factor to going TTB over IFS?
Sweet!
TTB is still IFS. But TTB are an easy way to get suspension travel. On my design with a 12in shock, it will end up with nearly 18-20in of wheel travel. Compared to a double A-arm, its also way simpler. It has drawbacks compared to an A-arm setup, like camber cannot be controlled or tuned beyond where it is initially set.
