Got a lot done this weekend. So I sold my axles and a bunch of other goodies for $4500. I sold my 5 wheels and tires for $3500. I found these older dynatrac axles for $5500. They were put in a jeep and just sat for years. They’re not prorock 60s, I believe they’re trail 60s. They have all the dynatrac stamps and Dynatrac serial numbers. They have 5.13s and ARB air lockers. They even came with the locker pump and all wiring. The same guy also had a full poison spyder cage…for $500!!!
I got the axles home Friday and started stripping everything down. I knew off the start that it needed calipers and pads. Dynatrac said I’d have to source rotors and redrill them. So I’ll take them to work tomorrow and cut the rotors. It took ALOT of research to find out what calipers and pads they used. The front are 78-87 JB6 GM K2500 calipers. The rear are 75-76 Cadillac Eldorado rear calipers(disc with cable e-brake).
I used rustoleum rust remover and let it soak for 30min, used a drill and grinding disc to scuff up both axles. They both turned out very well.
Got the front axle bolted today and everything lined up and went pretty easy. Hopefully next couple weekends I’ll get the brakes done and the rear axle in.
View attachment 585509View attachment 585510View attachment 585511View attachment 585512View attachment 585513View attachment 585514
Looking awesome, I'm super jealous on the cage find. I need one bad.
