Hey Everyone-
I've had my TJ for about 2 years– '97 4.0 w/ 90k miles on it.
It started throwing code 31 about a year and a half ago. First, replace the purge solenoid and gas cap. CEL went away for about a month. CEL back on, so I then replaced the charcoal canister (Duralast VC120 Vapor Canister) and cleaned out any charcoal from the lines. CEL went away for about a month... then CEL came back. Had Auto Zone do a scan- apparently the purge solenoid had gone bad again. So I replaced it again (PV300 Duralast Purge Valve/Solenoid.) CEL is back!
I've done a visual inspection of all the wiring and tubing and there are no leaks or cracks- on the new canister, I even clamped the hose connections to the aftermarket canister.
I'm about to lose my mind- any ideas? I'm in CA and have a smog inspection coming up so gotta get this fixed! Any and all ideas would be greatly appreciated!
