Here's a copy of the instructions that Sound German sends out also. And I haven't bought anything from him yet but he still sent me all this. So I don't see any issues sharing it now.
8hp kit installation instructions.
The 8hp kit is as close to plug n play as possible. The required inputs for the transmission to work with this kit are RPM, TPS, Torque, Brake switch or Brake lamp input. All other wiring is optional and for your use as needed. We provide Neutral safety output and Reverse light output to ground only. Speedometer output is a programmable and should work with any modern electronic speedometer or a speedometer driver such as Speedhut Speedbox. The harness is made to receive inputs via CAN or discrete wiring. Both are not needed. One or the other. This allows easy installation and no calibration requirements for supported CAN based ECUs. Also wiring with aftermarket ECUs and even a Carb engine or diesel with a TPS sensor and RPM sensor. The discrete inputs are programmable for virtually any sensor.
Note: After calibration the Save Cal Command button at the top must be pressed and then the control module must be powered down and then disconnected from Battery power for 5-10 seconds for the changes to take effect.
Some adjustments of setup are available in the PCS control module. All Calibration of the transmission is done via OBD to the 8hp control unit as it would be done in the factory vehicle. Aftermarket tuning devices will be required. The PCS software and cable will not make adjustments to the 8hp TCM calibration.
Mopar Crate or other factory Mopar ECUs with Star connector:
Power and Ground:
There are two power inputs. A switched 12vlts to be wired to power when the key is on and a constant 12vlt battery input. Ground to chassis or battery ground. These all must be secure and reliable. Power must not drop during cranking and check that ground differential during cranking or other high loads is not high. Either of these scenarios can cause the Control module to lose power or drop to a critical level momentarily and turn off. This can cause starting issues when using the N/S output and others.
Plug C4
Connect from PCS harness to Mopar Star connector any position.
Plug C1
Plug into rear passenger side of the transmission.
Plug C5
Plug into the 8hp shifter.
Unterminated wires:
Brake input Gry/Blk to brake switch. It is calibrated to 12vlt input for the switch by default but can be calibrated to a ground contact as well.
Neutral Safety output from PCS harness Pink/Blk to Mopar harness
N – Color: DG/OG – Gauge: 18 – Clutch Interlock:
Reverse lights output to ground side control of a relay for activating reverse lights.
Speedometer output:
This is a signal output to run and electronic speedometer. The Orange/wht wire will go to signal input of the speedometer. If the speedometer instructions show a 3 wire sensor diagram. 5vlt Ref and Signal ground are not required. These two wires are for operating an independent sensor. Power and ground to the Speedometer is required and this signal wire.
PCS software for monitoring data:
Please download the PCS tuning software at this address.
https://www.powertraincontrolsolutions.com//functions/download.php?dir=Software&file=TCM2800_Tuning-Install.exe
Install the software and Read the calibration from the control unit using the Read CAL tab at the top; with the Eyeball. Save this file on your computer. Go to
Software Setup select
Tuning Mode /
Advanced. Your screen should look like this after this is done.
After this open the Monitor Screen using the Monitor tab which looks like a speedometer at the top it will open the lightweight monitor by default. Change this to TCM 2600/2800 Datastream in the Selected Monitor pull down in the window and you should be able to see RPM, TPS, Turbine Speed, Lever position, Current Gear and vehicle speed. (See below) As well s other input output functions. With the engine running you should see RPM and Turbine speed and if your foot is on the brake digital input 1 and Cancel TCC should be on. You should be able to remove the shifter from Park if these conditions are met. If you override your shifter then it will not go into gear. The transmission will not come out of park if the engine is not running unless you use the manual override lever on the driver’s side of the transmission.
Aftermarket ECUs with TPS and RPM:
If using and aftermarket ECU or any unsupported CAN ECU TPS and RPM signals can be shared between control units.
TPS signal Yel/Blk will go to sensor input at the ECU. The 5vlt Ref. Red/wht and sensor ground BLK/wht should not be used. The ECU is already providing these to operate the sensor.
RPM input Orn/Blk will go to the tachometer output on an aftermarket ECU. This can also be shared with the Tachometer. Again, sensor ground is not needed.
Both of these signals need to be calibrated in the software under the Hardware Setup Folder.
TPS is under Analog inputs (x) TPS Calibration. Read the voltage using the Monitor in the box labeled Voltages Set the 0% voltage value and then press the pedal to full throttle and set the 100% throttle value. Hit enter after entering these values.
RPM is in the folder labeled SPEEDS. Set speed input pulses per RPM for Speed 1.
Applications with no other Computers:
Calibrate sensor inputs as per the instructions above after they are wired correctly.
TPS
Wire a TPS sensor to 5vlt ref. Signal ground and TPS input wires on unterminated harness as instructed on the TPS sensor instructions.
RPM
Magnetic 2 wire sensors can be wired directly to RPM input and Sensor ground.
Hall Effect 3 wire sensors should be wired to 5vlt Ref. Sensor ground and RPM input per Sensor instructions. Some sensors may also require 12vlt input or a pull up resistor to read the sensor.
Torque Map:
The torque map is used in these applications. It is TPS vs RPM and can be found in the Calibration/Tuning folder Main Torque Map. The break points can be changed to represent your engines operating range. This map must be representative of the actual torque, both positive and negative, being generated by the engine at the flywheel. If it is not the transmission may fail prematurely or simply not work at all. Reporting higher than actual torque is more desirable than reporting to little. See example map below.
Speedometer output:
Speedometer output setup pulses per mile is done under Hardware Setup / Speeds / (x) Speedo Output Settings Set the pulses per mile to match your speedometer to the speedometer in the PCS Software monitor.
Gear ratio and Tire size:
Set gear ratio and tire size under Setup Info / (x) Gear Ratios and Tire Size.
The transmission ratios are not necessary. Only final drive ratio and driven tire diameter.
If you are using the Mopar instrument cluster via CAN; the scaling is incorrect for this and you must adjust tire size to correct for this. I recommend setting it correctly, so the PCS software reads correctly on the Monitor screen. Get the vehicle to 60mph steady state and then adjust the tire size so that the instrument cluster reads 60mph while maintaining a constant speed.
Option connector and other CAN connectors:
In an effort to provide optional input setups and future expansion the harness is made with additional connectors for CAN. The option connector is used for items such as Gear indicators and Paddle shifters.
The additional 2 pin CAN connectors are not required for any particular installation and can just be stored in the harness if not used.
Sport and Track Modes:
Note: Modes are only supported if the Calibration in the 8hp TCM inside the transmission is set for these. This kit cannot activate modes that are not in the factory transmission calibration. ie a truck calibration does not have Sport and Track modes.
Sport mode and Track mode can be activated via the software and kept that way without wiring in or an additional wire can be added to the Main PCS 56 pin connector. Sport mode is set to digital input 2 (pin 3) and Track Mode is set to digital input 4 (pin 5). Nothing is required in the software if adding a wire to a switch. Simply add the wire to the correct pin and ground the wire and the mode will activate.
To activate either via the software without wiring got to Hardware setup / Digital Inputs / Invert button logic. Invert either digital input 2 for Sport or digital input 4 for Track.
If you have any questions about your installation or problems with the product or software. Please contact me.
Sound German Automotive
Russell Drake
russell@soundgermanautomotive.com
425-503-9233
