I am having issues with what I thought was a relatively easy light swap. I am installing the poison spyder 3 wire marker lights on my 99tj. My plan is to eliminate the 2wire side markers. So I have the front 3 wire marker/blinker that I want to wire up to the new led 3 wire. The blinkers work fine when everything is connected. No marker lamps. If I unplug the blinker wire, the marker lamp lights up. Currently the old 3 wire bulb is still connected and working. I used the 2 wires from the side marker for blink/marker and wired the ground to the grille behind the headlamp.
Should I be using blink/marker wire from further back in the harness?
