TJ hard top rear window replacement
Jlow720
Salt Lake City
Broke my hard top rear window for my 97 TJ and I’m trying to replace it without luck. The window that broke had holes on the bottom and a plastic frame that slipped onto the bottom. I’m hearing every hard top has a different window. I have no idea what 2 piece hard top I have.
I bought a PPR 12501-3202 from Quadratec but it seems like they sent me 12501-3212 because it had a bottom frame attached and was about 5 inches too wide without the bottom holes shown in the pic. It seems like the window for a 90-95 is the right size and has the holes on the bottom, but that doesn’t make sense
You have an after market top, not OEM. Not sure if that makes a difference but a pic of the window would be helpful.
The 3212 looks like the one in my 99. Yours may be different, as I said it is an after market top, but looks like mine from the back ??
I don’t have a pic of the broken window, but here is the pic of the window that did not fit and picture of the window with the holes that I believe was similar but says it’s for the YJ. I’m a little less than 47” wide and 26” tall. The YJ window has curve in the middle bottom for a handle which mine did not have on that plastic frame that slips on.
As someone else said, not OEM, methinks. That looks like a rally top. Maybe give them an email or call? The part number in this link looks to say YJ, TJ and LJ in it:
https://www.rallytops.com/product/j...o7Fg6UkTz6txL3QAmXiPWILmJuXrJ2XM98o4de_hBsgFz
I’ll bet there’s a chance they used narrower YJ glass in their design? If so, it might have been the cheaper, more available option? Also lets them stock less parts and make 3 separate tops with the same glass…
Upside is that if that glass will work, there’s a Black Friday coupon available.
Reactions: tnjeepguy
Top pic is for an 03-06. Just put a new one in my 06 yesterday. Yours is definitely an aftermarket top as someone else has mentioned.
