I have a Currie 4" lift and Savvy TT in the closet ready to go in. I am trying to forsee as many problems as I can and resolve them while i have the axles out for gears. I will be installing a Currie rear track bar and angled bracket, as well as a DC rear drive shaft. I have a 241 TC.
I was planning on running the Rancho shocks to start. But can buy something else if it makes any of these problems less annoying.
1. I assume the shocks will hit the coil buckets in the rear when the pinion angle is turned up. Will it be less of a problem on an LJ? Between clearance the bucket, adding new shock mounts, or using a relocation bracket, what is the correct solution here?
2. I know the rancho 5000x cannot be run upside down. Can the 9000 be run upside down? Would this help with clearance?
3. What is the consensus on shock options that offer the correct fit? I don't want to get into ride quality, but searched extensively, and there is just bickering. I need to pick a shock, and not sure what to choose. No cureent plans to outboard.
Tried searching extensively.
Thanks!
Thanks!
