Looks like the Thermocure worked. Will never be going back to the prestone cleaner. This stuff made the stuff coming out look like something I've never seen before. Idling at 200, 170 with the heater on. OBD and dash temps now line up as well.
Well, maybe not.View attachment 567636View attachment 567637
I don't know why its reading two different temperatures, but this was after driving around for half an hour and then going up a steep grade holding 2700rpm, no AC on. Went from 210 on the dash to what the photo shows. So I hooked up the scanner and it says 228, but it was at 231 before the photo.
I might go for a second round of thermocure and try more agitation and pulling the plug on the block. Heater is blowing very hot currently and if I run the heater it keeps temps down where it should be. Guessing there is just more stuff in the system.
New radiator seemed to do the trick. It flows much better than the one I put in. Now I'm running too cool though. Around 150. Maybe an air bubble in the system. Temp gun verified 144 upper rad hose just past the thermostat, 99 right below the temp sensor. At least its not getting hot now...I will see about finding a shop to maybe repair the mopar radiator as its build quality seems much better than the Denso I put in.
The only thing which will cause your too cool scenario is a bad thermostat. It’s stuck open.
Is it the same thermostat you were running when you were overheating?
Welp, found the issues, they sent me a 160F thermo not a 195F thermo.
The Mopar will fail eventually too. Usually cracks on the top plastic tank. And, likely can't repaired anyway. I have a Denso in mine and it's been great. I didn't notice earlier in the thread if you mentioned it but if it's still under warranty, return to a replacement. Also, was it purchased on Amazon? If so, it might be a counterfeit. Amazon sells a lot of counterfeit parts. Not sure if anyone is counterfeiting Denso radiators but it's always possible.
Anyone know the difference between
Mopar 52028186AC
Mopar 52028186AB
