JEEPSTEVENANAIMO
You can do it without removing the shroud. Takes a bit of wrangling around the AC lines, but it can be done.
sweet thanks!
do i need to remove the fan shroud to get the fan/clutch out? doing this today at work
ok so i did the fan clutch, now in total ive replaced the rad, thermostat, rad cap, water pump and clutch for the fan and my temp sits to the right of the middle of the dial (just to the right of 100) when i sat idling for 5-10 min with ac on the temps rose quickly. im thinking air bubble?
Buy a radiator funnel kit. Helps with air issues. I put mine on and rev it up a little and watch it burp.
Like this one:
https://www.amazon.com/Ultimate-Spill-Coolant-Funnel-Kit/dp/B089YHW5HR/?tag=wranglerorg-20
I just installed a ford explorer fan and heavy duty clutch. I can tell you that the clutch removal trick did not work for me at all. I had to rent a tool from the local parts store.
On the other hand the upgraded fan DID cool my AC down and keep my temp gauge from going over 210 even at idle and while on the hwy. I am more than pleased with the fan upgrade.
Whats the difference between the explorer unit and the factory one? i just did the fan clutch and all my issues went away.
The explorer fan has a heavier duty clutch and 10 blades. It moves more air
This is the fan I used.What years Explorer and do you have the Ford part numbers?
Dorman 620-155 Engine Cooling Fan Blade
This is the heavy duty clutch I used.
Hayden Automotive 2794 Premium Fan Clutch
A bolted right on without any problems.
Thanks, so it the fan 15 or16"? Amazon only gives the package dimensions.
Don't you just LOVE that crap? I see it more often than I should (which would be NEVER).Amazon only gives the package dimensions.
A lot of times when I'm shopping for something and there is a variety of different ones I'll skip over the ones that don't include product dimensions. There are quite a few products where you need to know that.
I use this from harbor freight. Same principle, but actually made to do the job right.
I loosened the fan clutch minutes ago with one smack of the wrench with a big hammer.
