Is war being declared on this front now?![]()
It more along the lines of an indefinite cold war…
More camping in ID. This is in Kingston in Silver Valley. I could spend all summer here…
View attachment 537295View attachment 537296View attachment 537297
We hiked the Pulaski Tunnel Trail, named after Edward Pulaski who saved 45 men from the 1910 fires that swept across the Western US. He was a self-taught woodsman. The 45 firefighters were panicking. Pulaski knew the area well and convinced them to follow him to a nearby mine. Once inside one man tried to run out. Pulaski pulled his pistol and threatened to shoot any man that left the mine. Nobody moved. He instructed them to lay face down in the mine to avoid as much smoke as possible. They all went unconscious. 40 of the 45 woke up. Afterward, they made their way into Wallace. Their shoes were melted off their feet, clothes were in tatters. After checking to see if his wife and daughter were alive, Pulaski remained blind in the hospital for two months. Between 75 and 133 people were killed by that Summer’s fire. Pulaski saved 40. We hiked down to the mine. It goes into the mountain 200 feet. It had been abandoned because no vein was found, like most mines.
It was the fires of 1910 that changed forest management methods to fire suppression. Since then methods have changed and they are considered necessary for the ecological health of forests.
Pulaski invented the “Pulaski” tool used by firefighters.
Welcome to Idaho
Pulling vacuum on the AC. I haven’t had AC since I bought the rig when I lived in TX in Dec 2016. I had a mechanic claim to fix it in 2018. I had cold air for 3 days and it cost me $600. Soon after we moved to WA. I don’t need AC except for about a month out of the year, and even then the top is off, but I want everything working.
Before the auto swap I had the system evacuated and during the swap I installed a new evap in the HVAC box. I also went through some of the system and replaced seals and valves. I’m just now getting to seeing if it will hold a vacuum. I’m keeping it under vacuum for two hours because the system was open for a few weeks. If it holds I’ll add some PAG 46 and then my refrigerant and we’ll see what happens.
Make sure you fill it to the system spec. Overfilling isn't a good thing.
Check the pump by the clutch for oil stains. Any oil at joints indicates a leak. When doing o rings or other connections use the compressor oil as lube and sealant.
You really ought to replace the accumulator/drier if the system has been open or had a leak that let out all the refrigerant.
Well,you have the tools to solve this at least.
What gauges and pump do you use? I’ve been thinking about getting some, but don’t really know enough about it to know what I want. LOL
Did you already replace your schrader valves for the service ports? That’s a common leak point
Yes, I replaced all the Schrader valves.
Well, thank you guys for that tidbit of info! I have a A/C Accumulator to go into the Jeep when I finally re-fill it and try to get the A/C working again after many years without it.
Was not thinking to replace the Shrader valves while I'm in there so thank you for helping to further spend my money in prep before I spend it 2-3 times draining & re-filling of a 'while you're there' part.![]()
I might as well just send you my valves since my system has a leak anyway. So annoying. At least it’s only summer for 1 month here.
Do the vacuum check first and see if it holds. No use filling just ”to see.”
Found a Soft Top Frame. He was giving it away. I was second in line. Tried to get it. Offered $25. He said the first guy planned to get it the day before but didn’t and now was waiting. Later he said, it’s not worth $25, but $10 would be nice. So now I have a frame. Just need the top now!
