After falsely blaming my last oil cooler (an oil to air heat exchanger with a thermostat) for a loss of oil prime (actually was a bad oil pump) and tearing it out, I decided to take a look around and see if there was a simpler and more effective option.
Then I remembered my 3.5 Ecoboost F-150 has an oil cooler. In fact, it is intended to both heat AND cool the oil, using the heat from the coolant.
In short, coolant is warmed by the engine, pumped through the heat exchanger (sandwiched between the filter and the block), exchanges heat with the oil, and then recirculates through the engine and/or radiator to pick up or dump out more heat.
Unlike the typical aftermarket oil coolers (which are performance focused only), the oil to coolant heat exchanger not only cools the oil once it gets hotter than the coolant temperature, it also heats the oil when the engine is still warming up. Oil heats up much more slowly than coolant, and in most engines, the radiator will begin dumping excess heat long before the oil has hit its operating temperature.
Why is this important?
1. Fuel economy (and emissions, to a lesser degree) - warm oil is less viscous and takes less energy to pump than cold oil. In addition, it also flows more easily and reduces parasitic drag on the engine. Addition of a oil to coolant heat exchanger is proven by OEMs to reduce fuel consumption, especially in the first 15-20 minutes of driving.
2. Engine wear - oil at its operating temperature lubricates more effectively than cold oil. The faster you heat it up, the less wear the engine receives during the warm-up cycle. This can also be achieved through the use of specialty oils (like 0W-30), but that is generally cost-prohibitive.
3. Performance - cooling the oil once it passes the temperature of the coolant helps reduce engine wear, helps maintain the engine at a more consistent temperature, and can even reduce the need of the engine to pull timing due to high temperatures. In effect, the oil cooler allows the engine to be run hard with much less impact and resulting wear. Effectively, an oil cooler turns the oil into a second coolant.
4. Extended oil life - the heat exchanger has the dual benefit of preventing the oil from overheating and also heating it up to operating temperature in a matter of minutes. The faster heat-up helps drive out condensation that can degrade the oil, especially on cars driven short distances. Reducing the peak temperature of the oil drastically improves oil life, especially as the oil passes 250°F, which might be seen at a track, idling on a really hot day, or climbing a hill on the freeway. This heat exchanger is partly why so many new cars can have 10,000+ mile oil change intervals, including the Ecoboost F-150s.
So, how do I install one in my TJ?
Simple. Buy 3 feet of 3/4 coolant hose, a long male to female nipple extension, an Ecoboost heat exchanger, a coolant elbow, and a few constant tension clamps. Install as shown:
The heat exchanger just sandwiches between the oil filter and the engine. Simply plumb the heat exchanger in series with the heater core (the larger of the two hoses). You don't even need to drain the oil or the coolant to make the connections (a little will spill out).
The hardest part of this was finding a nipple extension long enough to connect the oil filter to the nipple on the engine block. I ended up buying a round blank and drilling/tapping it to 1/2-20 UNF, and then using a sealant to insert a second male to male nipple.
Following the install of the heat exchanger, I've noticed that the engine (coolant) does take a bit longer to hit operating temperature since it is heating the oil as well. However, I've also noticed the engine more quickly approaches a more stable state, much like when you've been driving for 30+ minutes. City fuel economy has likely improved, but due to a whole lot of extraneous factors, I can't really quantify. It also seems to have increased the pinging threshold somewhat, meaning I can be slightly more aggressive with timing on 87 octane.
Interestingly, it also seems to temper the fluctuations in the coolant temperature due to changing loads. Since the oil acts as both a heat sink and a heat source at various times, it moderates the temperature of the coolant quite well.
Part number for the heat exchanger: ML3Z6A642A
Alternatively, look up an oil cooler for a 2021 Ford F-150 3.5 Ecoboost (non-hybrid).
This exchanger is probably a bit oversized for the TJ, given the Ecoboost runs at twice the horsepower and 20 PSI of boost. However, since it is a coolant to oil heat exchanger and not just an oil cooler, having an oversized cooler will not overcool (or overheat) the oil.
