Hello -
Researched this but was unable to find a solution or recommendation that was not related to low oil pressure or sending unit.
Have a rebuilt engine in my jeep that was done by one of the major engine rebuilders. Has run great for nearly 25,000 miles. The other morning started it up as usual (was in garage) and the check gauges light came on. Noticed the oil gauge was reading way low. Very uncommon, and I always keep a close eye on pressure and temp. Immediately shut it down, restarted same issue. Shut down again and restarted and oil pressure was then reading beyond the 40 mark pushing 60. Typically, when i start it cold, it runs slightly 40 PSI. Figured it was the oil sending unit. I did install a new one years ago when installed the engine.
This evening, pulled the sender unit and installed a gauge to read the pressure. At idle, it read 65-70PSI and as the engine heated up remained at 60-65PSI. As i manually revved the engine, it remained pretty much around the same mark, not increasing greatly with more RPM. When i installed the engine about 4 years ago, during initial start, I had the same gauge on the engine and took a pic. Going back to when the engine was new, it read around 50 PSI with the same gauge - now like mentioned fluctuating between 65-70.
I always run Pennzoil conventional 10W30 since I've owned it. That is what it currently has in it.
Did the following with no change in oil pressure.
- Checked oil level, right at full line. This oil has about 2000 miles on it.
- Removed, cleaned, and checked both breather elbows and pipes
- Replaced oil filter just in case there was some relief issue - used different brand as well,
- Inspected the filter internals after removal, no debris. Pretty clean actually.
- Checked antifreeze overflow, radiator, and valve cover cap for any signs of water into oil. The oil has no signs of emulsification. There is no sign of coolant loss or contamination.
- Idle is smooth and jeep sounds the same as normal. Distributor is tight, no signs of issue. Idle is not elevated at all either on start up. Very consistent with where it always is.
The oil pump and pick-up pipe were new at time of engine install and have about 25,000 miles on them. Oil pan was new as well at time on engine installation.
I change the oil every 3500-4000 miles. I could not imagine there being sludge build-up with 25,000 miles and pretty much all new parts when rebuilt engine was installed.
Puzzled by this, just though that my sending unit was on its way out. Unfortunately, maybe not that simple.
Any help would be appreciated, thank you.
