Help Me Choose Please!
All the way with LJ. Better move. (assume a black jeep is OK with you; I would/could never have a black vehicle, since washing is nearly unheard of)
My black TJ hasn't been washed in probably 7-8 years in this photo, it doesn't look too bad. :)
Edit: P.S. it still hasn't been washed since that photo lol.
Need to see frame photos.
I didn’t get any photos, but both frames have literally zero rust. I know these tend to rust on the inside, but I could not see or feel any at all. I poked around with a screwdriver too and could not find anything. I will crawl under them again before I buy. I would say frame/rust wise they are equal.
Reactions: John Cooper
I usually stay away from black too. I live down a 1/2 mile long dirt road. But hey, Jeeps are not supposed to be clean anyways right???
Go with the one you like best!!!!!
Reactions: 2001slvrstntj
Is the 4 speed auto that bad? I’ve read conflicting posts on here about them. Others issues with the 2006 year models??
The problem with the 42RLE in 2005/2006 isn't with the transmission itself it's with the transmission control module (AKA TCM) that was separate from the PCM in 2003-2004 but moved inside of the PCM (engine computer) for the 2005-2006 models. That's when the TCM developed a heat issue that can cause it to blow like an M-80 firecracker went off inside the PCM. There is a fix for that from www.wranglerfix.com that requires replacing it with a different model PCM but...
I currently drive a 2004 with the 42RLE and it works well but I still miss my previous (stolen) TJ with the 32RH 3-speed automatic which is pretty much as close to bulletproof as they come.
The other potential problem with the 2005/2006 models is the OPDA (oil pump drive assembly) that was redesigned for 2005. It has a lubrication problem that can cause cam and oil pump drive wear issues but I have read where that problem was mostly eliminated in later 2006 models.
Reactions: flyinfish
That’s the problem lol. I’m just not sure. Just thought there might be some brilliant insight on here that would sway me one way or the other. I really like them both!
I feel like the LJ is the smarter/better choice. But I like the looks of the Sahara a smidge better. Sahara is cheaper but value wise maybe equal deals??
The LJ is growing on me though the more I look at it.
Good info. A minus for the LJ I suppose.
Reactions: Jerry Bransford
well that answers your question ! buy them both :ROFLMAO:
