Front bumper removal to install AntiRock
GregBelleville
Southern California
Happy Sunday all. So I was planning to install an anti rock sway bar today and started removal of my Smittybilt XRC front bumper and ran into a problem pretty quickly. I discovered after removing the mounting bolts that the bumper is welded to the frame underneath.
This doesn't seem like it was supposed to be welded, I believe it should just be bolted on correct?
What would be the best way to break these welds? All I have at the moment are hand tools, I don't have a grinder of my own but could borrow one possibly if that's the only way to break the welds.
Are there other options? Sorry this is probably a stupid question, but I have no experience at all with welding or fabrication.
Let us know how the installation goes. I’d definitely buy the grinder because you may have to do some cutting on that bumper for the anti rock to fit.
Reactions: GregBelleville
At a point you start cutting & grinding more, I'd suggest a cordless Milwaukee grinder. A HF grinder will do what you need for now.
I cut and grind quite a bit and all those tools are corded or air powered aside from a Milwaukee die grinder for tight spaces. Nice to have but batteries drain so fast in grinding jobs. I always keep two HF or Northern Tool corded angle grinders laying around, one with a cut off wheel and one with a flap disc.
Chiseling off a weld is going to take forever, or never, unless the weld is really shit.
Forget the weld, cut the smittybuilt bumper from the weld, even though the weld doesn't look that good either.
A good sharp Cole chisel would cut the thin bumper metal quickly.
I bought the cheap HF angle grinder about 10 years ago for a single job I needed to do, and have needed it a few times since. It's done everything I asked of it, even with the HF disk set I got with it. I've found that HF tools will do what I need them too since I'm not using them on a daily basis, nor for anything difficult, (I live in Arizona, so corrosion is not a problem). $15
https://www.harborfreight.com/power...in-angle-grinder-with-slide-switch-58089.html
