We have several threads of ideas for 3D printed items. This is a place to share files, or to post links for purchase.
Drop a file, link, and description of anything you've designed and want to share, and I'll update the list below.
Interior
- @IOwnCalculus has a replacement panel for early TJs with the airbag switch in the console.
- @gbirk has a small storage bin for the rear right corner, designed to fit without carpet.
- @gbirk also has a connector/latch/lock for the rods inside your doors.
- @Steveorino has bushings for the back seats and front seats.
- @Eric M designed a 1mm spacer for the horn.
- Someone on Facebook called "Everyday Offroad TJ" is selling switch panels.
- See here for pics.
- @DMopar97 found a center console tray that works well with a center-console sub.
- Someone on Thingiverse has a 97-style AC slider knob.
- See here for the files.
- Someone on Thingiverse has a center air vent.
- @Urban 3D sells switch panels and more.
- @gbirk has a center console subwoofer mount and compatible cubby.
- @chili_pepper has a circle clip for the factory vinyl shift boot.
- @KingCarGuyZ created mounts for these hidden strobe lights (for roadside, mail, etc.)
- See here for description and attached files.
Exterior
- @Queticon made some OEM-style mounts for the factory fog lights.
- @andya has a rear camera mount that attaches between the tail light and the tub.
- Someone on Thingiverse has coil spacers.
- Read the page's updates about rear spacers failing due to heat.
- @sab has a plug for the opening above the front coils.
Engine Bay
- @chili_pepper designed a cover and filter housing for the cabin air intake.
- @Tinnitus_Z has a heater blend door actuator "connector thingy".
- @Mogul345 has a EP26 LED flasher relay mount.
- @IrishWake has a fuse puller that fits in the PDC.
- Someone on Printables has a cabin air filter adapter.
Audio
- @Chase_C has some speaker pods for the front dash.
- @wkelley70 has a tweeter pod, specifically for Polk Audio DB5252 DB+ Series.
- @LaZ8787 has a sliding tray for the slot under an aftermarket, single-din stereo.
- See here for pics, write-up, and files.
- @BillNyeIsHigh modified @Chase_C's files to fit 6.5s.
- @LJGreg has a part for putting 6.5s in the overhead pods of late-model TJs, and one for mounting BLAM tweeters to the A-pillar.
- Someone on Printables has pods for front "upper" (bar) speaker pods.
- See here for pics and files.
- Looks like it would interfere with the soft-top channel?
