STICKY Share Your 3D Design Files (or Sell a DIY Part)
SSTJ
Lifetime Supporting Member
SE USA
We have several threads of ideas for 3D printed items. This is a place to share files, or to post links for purchase.
Drop a file, link, and description of anything you've designed and want to share, and I'll update the list below.
Interior​
  • @IOwnCalculus has a replacement panel for early TJs with the airbag switch in the console.
    • See here for the file.
    • See here for a pic.
  • @gbirk has a small storage bin for the rear right corner, designed to fit without carpet.
    • See here for an editable version.
    • See here for why to print in PETG, not PLA.
  • @rasband is working on a custom switch panel.
    • See here for pics.
  • @gbirk also has a connector/latch/lock for the rods inside your doors.
    • See here for another pic.
  • @Steveorino has bushings for the back seats and front seats.
    • See here for a description of the back, and here for the file.
    • See here for a description of the front, and here for the file.
  • @Mogul345 has replacement pins for sun visors.
    • See here for description and files.
  • @Eric M designed a 1mm spacer for the horn.
    • See here for pics and files.
    • See here for pics and discussion.
  • @LaZ8787 has a highly customized mount for an iPhone 15.
    • See here for pics, write-up, and files.
  • @Mike_H has a replacement auto shifter bezel.
    • See here for files, pic, and description.
  • @JCaspary has some files for center vents.
    • See here for files, pics, and description.
  • Someone on Facebook called "Everyday Offroad TJ" is selling switch panels.
  • @DMopar97 found a center console tray that works well with a center-console sub.
    • See here for description and pics.
    • See here for the main file use.
  • Someone on Thingiverse has a 97-style AC slider knob.
    • See here for the files.
  • Someone on Thingiverse has a center air vent.
  • @Urban 3D sells switch panels and more.
    • See here for a description and links.
    • See here for a plug from a form member.
    • Website's TJ-specific section is here.
  • @gbirk has a center console subwoofer mount and compatible cubby.
    • See here for the post.
    • See here for the mount description and files.
    • See here for the cubby description and files.
  • @chili_pepper has a circle clip for the factory vinyl shift boot.
    • See here for description.
    • See here for file.
Exterior
  • @Queticon made some OEM-style mounts for the factory fog lights.
    • See here for his original post.
    • See here for an updated file.
  • @Sudo created some center caps with the Jeep logo and seven beer-bottle slots.
  • @Jezza has some end-caps for the OEM rear bumper.
  • @gbirk has a spare tire bumper spacer.
    • See here for files.
  • @andya has a rear camera mount that attaches between the tail light and the tub.
    • See here (and scroll down in first post) for a pic of it in place.
    • See here for the printable files.
  • Someone on Thingiverse has coil spacers.
    • Read the page's updates about rear spacers failing due to heat.
  • @sab has a plug for the opening above the front coils.
Engine Bay​
  • @chili_pepper designed a cover and filter housing for the cabin air intake.
    • See here for pics and description.
    • See here for pics of installed parts.
    • See here for link to printable files.
  • @Tinnitus_Z has a heater blend door actuator "connector thingy".
    • See here for original description.
  • @Mogul345 has a EP26 LED flasher relay mount.
  • @IrishWake has a fuse puller that fits in the PDC.
  • Someone on Printables has a cabin air filter adapter.
    • See here for discussion.
Audio​
  • @Chase_C has some speaker pods for the front dash.
    • See here for his post and others' feedback.
  • @wkelley70 has a tweeter pod, specifically for Polk Audio DB5252 DB+ Series.
  • @LaZ8787 has a sliding tray for the slot under an aftermarket, single-din stereo.
  • @LaZ8787 has some 5.25" speaker grilles.
  • @LJGreg has a part for putting 6.5s in the overhead pods of late-model TJs, and one for mounting BLAM tweeters to the A-pillar.
    • See here for the pod ring file.
    • See here for the tweeter mount file.
  • Someone on Printables has pods for front "upper" (bar) speaker pods.
    • Looks like it would interfere with the soft-top channel?
THis is a great idea with so many discontinued and hard to find parts (y) atleast those of us with no 3D printing capabilities can purchase parts from someone who has it !!!!
Reactions: jdsouther
I'll throw out my replacement panel for early TJs with the airbag switch in the console. Worth noting that while I designed it around a 0.312" incandescent indicator bulb from BGMicro, they've since closed up shop so a suitable replacement light would need to be sourced to keep the airbag controller happy.
Reactions: SSTJ
I posted this in another thread, but here is my small storage box for the rear right corner of the Jeep. Deigned to fit without any carpet.
https://www.printables.com/model/226636-jeep-tj-rear-fender-storage-boxTinkerCAD link if you want to make changes: https://www.tinkercad.com/things/53Zc5quTHH8
For those us us with guns, here is a gun rest I designed for when I have to dig into the safe and need somewhere to lean a rifle for a minute.
https://www.printables.com/model/237995-steel-safe-magnetic-rifle-rest
CMMG .22LR conversion bolt for AR15 storage box:
https://www.printables.com/model/179329-cmmg-22-lr-conversion-bolt-storage-box
Reactions: LaZ8787 and SSTJ
[URL]https://www.printables.com/model/226636-jeep-tj-rear-fender-storage-box[/URL]
[URL]https://www.printables.com/model/237995-steel-safe-magnetic-rifle-rest[/URL]
[URL]https://www.printables.com/model/179329-cmmg-22-lr-conversion-bolt-storage-box[/URL]
Thanks for the storage box. Going to have to give that one a try. :D
Reactions: gbirk
I would love one of these panels.. just the blank panel.. no provisions for lights or switches.. I was going to fab one from plexiglass or some left over kydex. Can you do one with no switch/light? I figured I would just stuff the stock panel under the console so I don't get any idiot lights
I really would not recommend this. The whole reason I started that project was because my airbag switch was failing, and hitting bumps on the road was enough to cause it to intermittently switch off the passenger airbag. You wouldn't see or know about that if your airbag switch is hidden. Mine no longer has any way to toggle the airbag off, but the indicator light is still necessary both to keep the airbag computer happy, and to alert you if something is not as it should be.
Bump. I know there are some more floating around out there.
Still prototyping, but here's a new switch panel I've been designing and refining.
A 2 piece design that let's you get to the wiring w/o taking off the whole center bezel would be nice. I built a similar thing out of sheet metal with a screw on front plate, but a 3d printed piece would do well I would think. (Obviously you have to take off the center bezel to do the initial install.)
Reactions: inkedrose
That's a great idea!
