Winch covers?
I have a Bartact. Its been great. I have a smittybilt X20 winch and the bartact is made for a Zeon, but the shapes are similar enough to work.
Someone here recommended this one:
https://www.amazon.com/gp/product/B0894CCTXW/?tag=wranglerorg-20
It will eventually fade, I'm on my second one, the first one lasted a year and a half. It costs $16 - when it gets tatty, buy a new one. I had a different one that didn't even make it 9 months here in Florida - so this one I'm glad to replace it every 18 months or so...
I've had the same cover for 2+ years now. It's faded, but keeps the mud off the winch!
Garage queen here. Plus the Warn XD9000i houses the solenoids over the winch line, so it rarely gets any sun. The worst that can happen up here is dust getting into the fibers of the thread, but I wash the line periodically.
In addition to protecting the line, it's better for the winch to keep it clean and dry, just like most electromechanical devices. I'm pretty lazy, and the easiest way to clean something is to prevent it from getting dirty in the first place.
But it won’t look as bougie.
Got my new to me warn 9.5ti mounted and the $8 winch cover I had on my smitty doesn’t fit. I’ve got WRG line, fairlead and thimble. The sun down here can be brutal.
1) do I need a cover?
2) if so, any recommendations?
i had that exact winch on my aev jku...the cover caused all sorts of corrosion issues. i live in a rain forest tho...so results may vary
Mine's usually too dirty for the sun to penetrate :)
Reactions: JMT and srimes
I think any decent winch should survive the elements just fine. I know my Smittybuilt 5 year old winch (which is used regularly) hasn't suffered from a bit of sun/ rain, dirt, the occasional full submersion...
I sealed mine with RTV around the motor housing and the drum support and used a breather hose for venting. Unless it has some other water proof/resistant rating, after a submersal then it will need to come apart in order to clean, remove rust, and repack the gears.
My smittybuilt x2o is listed as "Waterproof" right in the name :) Description also reads:
Every X2O winch features a Series Wound 6.6 HP motor that is completely sealed, as well as a 3-Stage Planetary Gear System. The X2O winch features a completely waterproof 500 AMP solenoid pack...
I figure, if they call it waterproof, well, it better be :D so far, so good, it's been fully submersed, and 'run' submersed more than once with no issues so far.
  • Love
Reactions: JMT
What you really need to protect is the line from UV if you have syn line.
Solenoids can get wet and go bad but most new winches don't have solenoids. So they are pretty immune to most anything.
I have made line and spool covers for my winches that have syn line if they are in constant sunlight.
Amazom sells Kydex sheets, large and small. Measure what size you need and order it. Take a heat gun and form it so it can snap off when you need the winch. Cut to size.
got a picture? would love to ditch my shapeless bag held on by a bungee. This kydex https://www.amazon.com/Plastics-2000-KYDEX-Sheet-0-080/dp/B077S5N6TP/?tag=wranglerorg-20
Reactions: John Cooper
Reactions: red02tj
