Yes I am well aware of what & where the TF999 came from... The TF727 was/is one of the easiest auto transmission to rebuild too compared to other brands.
I "hear" the 32rh is pretty easy to rebuild...
A Q-jet on a SBC works as well as anything I've had off-road . Unlike a Holley it will work in extreme conditions and angles . I like you idea about Advance Adapters , they are a great resource . However our friend in Australia might need a local , more home brewed solution . Thanks.
I actually got the kit off them and they said it’ll be fine but as I started doing more research I started second guessing myself
You didn't like my joke?Don't know, never had one on my bench.
I've ran Q-Jets and Holley's & Edelbrock carbs plus Webers and a few others I can't remember right now and they all had fuel slosh during dicey shit off-road or when at extreme side angles. And having your carb flood out as you're going down a steep hill just SUCKS...
Your jokes are ..........or
I've never seen that with a Q-jet .
Another possible solution is to get a 305 chev I haven’t had much to do with them so I’ll have to do some research
The marine versions have an extended bowl vent tube to alleviate fuel slosh issues. Would probably be a good mod for an off-road application.I've never seen that with a Q-jet .
I’m
hahahaha I feel your pain hahaha
I have give @lBasket a hard time... It's my purpose here... He's a good guy.
I hope that my statement of opinion and experience does not come across as being rude because I don’t mean it that way
The small block Chevy was popular in the day for many reasons, mostly because of the aftermarket speed parts availability and the parts interchangeability all the way through the series from 1955 until the late 80s. That said, many newer technology engines far surpass the small block Chevy. Additionally, such engines are old enough that they are economical to purchase on the used market or from a wrecking yard.
I know that there will be people insulted by my comments about the small block Chevy. It was popular to the point of being religion.
Also more modern engines have fuel injection. I peruse your original post quickly, but did not see a statement about your purpose and mission for this rig. If you will be off Roading in a way that places the vehicle and other than level positions, fuel injection is an extremely Good improvement.
There are numerous more modern engines that are much better than the antiquated small block Chevy and would serve your purpose much better again. This is strictly my opinion based on my 60 years or so experience building engines, modifying cars and so forth.
The important thing is you’re building a vehicle and enjoying it so I hope this comes across as constructive and not criticism.
Have fun and very best of luck with whatever you build.
No offence taken mate I know that it’s old technology and at my age it’s hard to move on from something I’m so familiar with I can fix a carby or a dizzy with just a few tools and going into the outback of Australia you stick with what you know efi is good but it’s not for me I don’t trust computers and all that other stuff on engines theses days it’s not being used for anything other then towing our camper trailer in and around the Aussie outback I’ve had the 350 and adapter kit sitting in my shed just waiting for the day the 6 cylinder had enough and it did luckily not too far from home so there you have it I’m just a bit worried about the 32rh but I’ve found some stuff on line that’s put my mind at ease there a very strong transmission and if you look after it it will be fine once again i take no offence to anybody voicing there opinion because that’s how we learn and that’s why I’m here cheers mate
One of the things that drew me to the Jeep TJ was because it was antiquated , Other than fuel injection the early TJ's are a throwback into the 1970's. Every factory "improvement" that has happened to a TJ as time went on has just created new problems . And these are relatively simple Jeeps. The JK and JL/JT are tech nightmares in my opinion . But then again , so are new Toyota's , I didn't trust some of the newer tech they are using. If you can post some photos of your Jeep I would love to see it . Have fun with your project !
