New to the forum; also new to the TJ life.
The forum has been a lifesaver over the last month or so with my TJ project. @Jerry Bransford seems to be very knowlegable as I have seen and learned to trust his advice and expertise on several different topics!
Recently picked up a 2000 Jeep TJ 4.0L (197k miles) from a high school friend (it was it first car @ 16) that was not running and had been sitting for 2-3 years for $2500. Friend went to aircraft mechanic school and had to commute a good ways each day so he parked the (running at the time) jeep and drove something else. After losing interest, he finally gave in to selling to me.
Same day I picked it up and trailered it home, I had it running - fuel pump was shot and gas was bad. After a trip to Auto Zone and a few hours of labor, I had the pump changed and Jeep up and going. Spark plugs have also been replaced.
The Jeep had a terrible death wobble, but that has since been resolved after ripping out everything from the front end and replacing with new parts. A new set of balanced tires helped as well.
Now to my current issue... I'm experiencing some shuttering/slipping with the transmission (32RH). I've read several posts on here regarding fluid level and shifting manually using the gear shifter (1st —> 2nd, 2nd —> Drive). Fluid level is a little over the high mark when in Neutral, running, and warm. Trans does not shutter/slip when manually using gear shifter between 1st and 2nd, but 2nd to drive has a mild slip still.
I've read a few things about adjusting TV cable... could that be what is needed? Also read a little about adjusting the bands. I'd like to eliminate all "inexpensive" possibilities before taking it to a transmission shop and ultimately rebuilding/replacing the transmission. I do, however, understand that it has nearly 200k miles on it and may very well need a transmission at this point.
Any guidance/help is much appreciated!
P.S. I had to put about 4 qts of trans fluid (yes, ATF+4) when I first brought it home. I also had to retorque the transmission pan bolts due to it leaking.
