As some of you know I bought an 05 TJ Sport last Monday. I've had some time to spend with it so here are a few things I've learned about it.
-The radiator is cracked. Yep, when I test drove it I thought I smelled coolant. After a drive yesterday I smelled it again. Popped the hood and saw the crack. New Denso radiator on order from Rock Auto along with hoses and radiator cap.
-Fog lights are missing. Build sheet said it had fog lights. None when I bought it. You can't even tell they were ever mounted on the bumper. While driving, I noticed a light icon flickering on the dash. Seems it was for fog lights. Then I figured out it had the multifunction switch for fog lights, the fuse and relay installed. I pulled the relay and fuse and that seems to have taken care of the flickering light. I suspect a previous owner removed the fog lights because of the flakey MF switch. I typically don't use fog lights so not really an issue.
-Multifunction switch has issues. (see above). Are there any aftermarket MF switches worth a darn? I see Crown makes one. I want to have one on hand before I take apart and clean the one that is in there now.
-Fuel filler burps gas when filling the tank. Anyway to correct that? On the JK I owned, there was a flapper check valve in the tank filler line.
This thing is a blast. So far I've changed the oil/filter and installed the Crown OPDA.
I have to say the wealth of knowledge on this forum is amazing. I've been on many forums over my many years and this is one of the best.
