What differential gaskets?
Rentmoney
Southport NC
2001 Jeep TJ sport 4.0 l I understand I had the Dana 30 front axle and the Dana 35 rear. Can anybody give me the numbers are where to get the gaskets for these axles AutoZone and advance have no idea what they're talkin about
I ran into the same issue and was never able to find them. I had to bring in the old one so they could try matching it up. Unfortunately I did not keep the boxes. Anyone able to help here?
DANA 35 form the auto zone website:
Product Details
Part Number:P27801
Weight:0.34lbs
Warranty: 1 YEAR
Notes: Axle housing cover
Rear axle. With Dana 35/AMC-15 axle. 10 bolt holes. Paper.
Material:Paper
Package Contents:Gasket
Package Quantity:1
DANA 30 from autozone
Product Details
Part Number:RDS55019
Weight:0.18lbs
Warranty: 1 YEAR
Spicer 30-AF. 10-bolt holes. 7.125" Ring gear
Item Grade:OEM Standard
Material:Composite
Package Contents:Contains the Following Seals and Gaskets: Front Drive Housing
Package Quantity:1
Product Details
Weight:0.18lbs
Warranty: 1 YEAR
Material:Composite
Package Quantity:1
Make your own with quality gasket material, using a small ball peen hammer to punch the
and assemble with PERMATEX liquide aviation gasket on both sides of the gasket
from Dawson Creek
“MILE-ZERO ALASKA HIGHWAY”
from Dawson Creek
Sorry,
I missed part of the sentence:
Use small ball peen hammer to punch out the boltholes
My dad had a hell of a time getting his fabricated 10 bolt diff cover to seal up. Tried silicone twice (to be fair didn't wait for it to dry completely before filling but we've never had an issue in the past). I think he couldn't find the correct lube locker but he bought a gasket from the local parts store. Still dripped. Finally he bought a piece of gore tex and custom cut a gasket out of it and it's sealed up perfectly since.
MOPAR Gear Lube RTV MS-GF44C P/N 82300234
High Temperature Gear Oil and ATF resistant
Clean both surfaces thoroughly and apply some of the Mopar RTV, allow to set up for 30-45 minutes and install the differential cover, allow to set up for an hour and then fill differential with gear lube to proper level.
Reactions: Fouledplugs
Imagine all that, and he could have just used RTV and been done with it.
I've had good success in the past using great stuff gasket maker/sealant. I use black RTV to seal timing covers and such on Land Rover engines so I'd imagine it would easily hold up for a differential.
Since I had already purchased the paper gaskets I put a thin layer of RTV on each side works great no leaks. Only took 2 and 1/2 quarts for the front and rear specifications said it would take three. Will drive tomorrow and check fluid levels. I appreciate everyone's help
Reactions: CodaMan
