04 I6 TJ Sport
Over the last several months I’ve had the check engine light come and go.
The light is turns off about every third time I fill up with gas, then randomly will come on one morning as I’m driving to work with the P0456. I noticed this usually happens when the gas tank is below 1/2.
I also started noticing that when the light came on my lowest AC setting stopped blowing when I was stopped. 2-4 would work at a stop, and all 4 setting worked when I got over 20 mph. When the light went off, the AC would work normally.
I followed every vacuum line and found none of them were leaking. I replaced the gas cap.
What else can I check? I seem to fix it somehow, then it just shows up at random.
