Thanks Wranglerfix!
Stump
Utah
Hopefully this story helps someone else. I started having some electrical problems with my 2005 Sport with a 6 speed. I started getting an intermittent no crank situation. Jumping the starter would crank it, but no spark. I also noticed that my OPDA was a little loose, and it caused a crank/cam disagree code. I tightened that. No more codes that way. I still had occasional no crank/no start problems with no codes. I went the cheapest route I could think of. I replaced the cheapie crank position sensor that I put in last year when I replaced a disintegrated throw out bearing. I did the clutch at the same time, of course. I broke the crank sensor putting the transmission back up into place. Remove that like the instructions say. Oops.
Anyway, after replacing that sensor, everything was fine for about a week, then this:
P0032 heater control circuit both banks and circuits.
P0031
P0038
P0037
P0051
P0052
P0057
P0058
All of those came on at the same time and the Jeep died. I cleared the codes, and drove another 1/4 mile and it happened again. Haven’t seen those codes since.
Since then, I have been frequently losing all my gauges, gas light on, MIL on, and code U0155. Sometimes it is self healing and the MIL even goes out. It usually shuts down a little while later. It usually restarts. If not, disconnecting the battery terminal and reconnecting will allow it to start. Last time I did this, (almost all of this was on a camping overnight with my daughter) I left the battery disconnected for about five minutes while I helped my daughter with something else. 42 minutes of good living, according to the clock on the radio.
The one other anomalous code that I got was P0508, Idle air control system circuit low.
I have also gotten an occasional P0300 Random/multiple cylinder misfire
Coincidentally, these would most often occur going downhill at idle/engine braking.
Yesterday I put my new PCM in from Wranglerfix. 5 minute procedure. Fired up and has been working fine for two days now. I ordered that PCM on Tuesday, late afternoon. It arrived on Thursday. I was out of town, so I didn’t get it in til yesterday. I have a few hours of driving on it, and it is a different experience now.
I am fairly confident that was the answer.
I bought this Jeep a year ago. I should have the rest of the “isms” worked out of it soon. :LOL:
P0031
P0038
P0037
P0051
P0052
P0057
P0058
that is a ride of the month photo if I ever saw one!
Man it sure was in a pretty spot -
Maybe we should start a “stranded ride of the month” contest. That could get interesting.
Reactions: Stump
On your multiple misfire code. Check and make sure your Crankshaft position sensor is not sitting on top of the manifold. I had the same intermittent issue and the little plastic spike had fallen off and it was sitting on top of the manifold and it was getting too hot there until i zip tied it up in the original location away from the metal etc.
Thank you. The crankshaft code was legit. As I started troubleshooting before I replaced the PCM, I found that the OPDA was loose, causing a cam/crank disagree code. The 0300 random misfire code hasn’t been a problem since changing the PCM. I did check the security and integrity of the sensor. I don’t think it is an issue. I also never felt any engine behavior that resembled a multiple misfire issue. I am assuming it to be erroneous like the other 10+ codes. I have made a pretty conscious effort to induce all of the codes that I was getting by doing what I was doing when they would tend to pop up. All good so far. 🤞
Reactions: Mitchrb1
