Soft Top Door Seal
Christian.mers
Point A to Point B
Huntington, West Virginia
I’m sure this is out there somewhere but I wasn’t wondering what you all would do to fix this?
My soft top upper doors don’t make a correct seal and that causes water to leak in every single time it rains. My soft top hold down plastic has broken as well.
Ground down some of the torque boxes and frame, a little rusty in and out but I’ve seen far worse. Need to jack up and undercoat it. Not sure what I’m looking for on the trim pieces
At the top of that trim piece is a rectangular hole, and the end of your door surrounds are supposed to go into that hole--double check that your door surrounds are in, and that area isn't broken.
Still searching. Kind of just forgot to check and then the jeep went down and I just started driving it again and it stormed pretty bad (this is only from about 30 minutes)
I was parked on a slope favoring the passenger side so I’m sure water just glided off the soft top and down
And this plug with the aqueduct lines going to it should be removed and replaced with a plastic jk plug.i took a small hole punch and made a hole in them.
