Slip yoke eliminator recommendations
hunterhabec
Durham NC
So I am still sort of new to jeep mods but I just had a 3.25 inch rough country lift put on my 2006 tj and I couldn't help but notice that they dropped the transfer case which in my opinion defeats the whole lift kit point. But anyways I am trying to figure out if I can just put the transfer case back into stock position or if something will snap if I do.
If that is not possible I am hearing I need a slip yoke eliminator and a new driveshaft to raise the transfer case back up does anyone have any recommendations on driveshafts or slip yoke eliminator kits.
Reactions: lBasket
JB Conversions shorty SYE is the shortest one out there I think
I put an Advanced Adapters SYE on my 231 transfer case when I installed a raised skid plate and I'm happy with it. I also used a Tom Wood's double cardan driveshaft. No issues and great customer service from Tom Wood's.
I don't think you can go wrong with Adam's Driveshaft either. I have no personal experience with them but have read that a lot of others have been happy with their product.
well my other thing is can I just do a SYE with the stock driveshaft or do I have to upgrade driveshafts.
Reactions: MountaineerTom
It requires the following to fix:
1) SYE. Go for the JB conversions SS SYE
2) adjustable control arms in the rear. Go double adjustable.
3) Speedo Healer
4) rear DC driveshaft
3) Speedo Healer
I have already done the control arms I had them installed with the lift
What is a Speedo Healer I have never heard of it and when i look it up a motorcycle tuner comes up
I’m
if you get a Super Short SYE you lose the mechanical Speedo gear, so the Speedo healer resolves that problem.
If you decide to get a normal SYE then you maintain your Speedo gear. However, with bigger tires you’ll need to get the right mechanical Speedo gear so your speedometer and odometer are accurate.
