Marking of driveshaft at yokes
Danarch
Orangevale, CA
I marked the front driveshaft at pinion and transfer case. My markings at the transfer case side (double cardan joint) came off while removing the u-joints. Is that an issue? Seems like it shouldn’t be as the driveshaft is what is balanced. I know when I replace the boot at the slip joint I need to put it back exactly the same way it came apart.
