Rubicon Locker dash lights
06melanore
Wilmington oh
Ok so I have an 06 lj rubicon. It has a 44 and 9inch with detroit lockers. No pumps or wires going to axles. I have pulled relays and offroad fuse and still have the locker lights flashing. What do I need to do to disable the flashing lights? Thanks
Probably the easiest way.
The cluster logic flashes the lights when the locker state does not equal the state requested by the dash switch. In theory they should go off by pushing the switch once or twice, or by pulling up on the switch. 3 states: both unlocked, rear locked, both locked.
Pull up on switch. Still flashing?
Try pressing the switch once. Still flashing?
Press the switch again.
That's all 3 possibilites.
If that doesn't get it to go off, there's probably something going on with the wiring that went to the axle sensors.
The cluster compares the switch request to the axle sensors, which of course aren't there.
