Hey everyone, I'm new to the site talking to another member on here raymondt recommended I ask the jeep gurus on here as I have an issue that's rather puzzling.
Let me start by saying when I first got the jeep the rear brakes did not work at all was the main issue. jeep was totally stock except I found out that the rear end has possibly been changed at some point because there is no spots for the abs sensors on the diff and the abs plug is just hanging under the gas tank. Thinking that maybe the abs pump had something to do it maybe, I planned on rebuilding it all as I have since totally redone the jeep top to bottom since.
Moving forward I have ripped out the abs pump, p-valve, all new brake lines and hoses, new drums, shoes, adjusters, wheel cylinders, adjuster cables ect I even now changed the master cylinder, replace the stock p-valve with the adustable. And the issue is still there the back brakes just will not work!
I have spent alot of time reading your threads trying everything I could different tricks like the adjuster cables being installed wrong (which I will admit I did do) but I fixed that now, brakes have been bled and re bled many times. Adjusted to the drum over and over again. P-valve is wide open and getting flud slash pressure to the rear brakes that not the issue. They are just not grabbing. I can pull the emergency brake as hard as I can and not stop the rear tires on jack stands without hitting the top of the reach. With my foot all the way down on the brake pedal and the emergency brake applied the wheel can still be spun by hand.
So now on another thread here I have read about these two different brake shoes listed by raybestos brakes but they both use the same drum. Part # 769pg and 538pg both of which are listed for a 1997. Has anyone been down this road? Not knowing what the diff is exactly maybe something as simple as the wrong shoe?
I'm now at a total loss and being 20 grand into this project now and a 2 year build I should be able to figure this out but here I am! Any help would be greatly appreciated
