Parasitic battery draw *help*
Aidynl
Kelowna
Hey guys I have multiple fuses drawing current and they all draw the exact same amount of current almost like there all connected together.
The fuses are
-MSFW #27
-ASD #9
-HD/LP #10
-Access.2 #26
-Radio #20
-Park ips #1 (behind glove box fuse box)
****Drawing about 7.5 Amps when off***
I've tried Disconnecting the alternator, Checked the radio wiring harness, Unplugged all connections going to the steering Colum, pulled out the fuse box in the engine bay and checked all the wires. Very lost with this and I am completely running out of ideas of what it could be. any other things that I could check would be greatly appreciated thanks.
2003 Jeep Rubicon tj 4.0 Manual
Have you consulted the appropriate FSM for your wrangler year? Look over the wiring diagrams and see what these might have in common.
How / where are you checking for current draw?
When did the problem start?
Is anything acting weird / abnormal?
Have you checked your relays to see if one has malfunctioned?
Let's eliminate some stuff.
