Hard to tell from the picture, but that looks like an industry standard connector pin of some sort. Check with Newark, DigiKey, etc.
I’m starting to question whether you are human.
No just apparently unemployed lol
You should destroy your Jeep more oftenI’m loving watching the videos and following your progress. It’s amazing how quickly you got it all fixed up!
I'll let someone else do one next time...but I'll come help!
Actually might do it again... we're looking at options for my wife's JK... frame is bent, tub is bent... can't/don't want to afford something new. B and R has a 2014 JK coming in on Tuesday and if it's clean...then $2500 for tub, frame, doors, hood, grill and here we go again... although I'm probably two months from framing my shop...and getting a lift...so we'll see.
Been puttering on details.
Got the new Luk master slave bled after screwing up and pushing the rod out. Basically just unbolted it from the transmission and pushed the slave rod in a dozen times with the master lid off. Topped off the fluid and it's perfect.
Still want to find a barbed fitting or something to patch the line... seems like something super easy to have in my magic Crown bag of tricks.
Messed around with the speed sensor. Tried figuring out from research how to clock the housing and then realized that I already knew where it shouldn't be... actually two of the four possible positions. So I rotated it another 90 degrees and presto it's working perfectly albeit all the in and out might be seeping fluid. Going to run the torn up gear for a week and put in the one I bought for 35s...never installed it because the one for 33s was pretty damn close. And drain and flush all the plastic out. Might get my endoscope in and see if I can see the screen on the oil pump... hopefully not jammed with plastic bearing chunks.
Missing bolt on my Swayloc. Can't identify the thread and pitch...think it's M8 or 5/16 fine... nothing fitting. Reverse thread?
Check engine light came on for the speedo sensor. No return of cylinder 6 injector or downstream O2. Cleared, clocked and hasn't returned.
Part 5 YouTube drops Wednesday morning...1-3 are live now. Had to YouTube edit 3 because I forgot to delete and trim off 4... sometimes easier to edit all the footage and then find natural breaks.
Took the bumper off the JK. My poor tortured M8000 winch works perfectly despite being the tip of the spear that killed my Jeep... perhaps it was revenge for cooking three motors.
Driver's side? I can take a gander at the one I have sitting uninstalled if you would like.
Yes please! I think my threads are dinged up and it needs chased with a tap.
And get that damn Swayloc installed... it's too awesome to sit in that box...which...granted is a piece of art unto itself.
Thanks!
Mac
It'll find it's way on there eventully, I need to get all the other parts and pieces to do the lift and belly up, then it will be time to put it all together.
I'll head out and take a look and get back with you shortly.
Chalis isn't too far away...and I've tried and failed twice to get to the Magruder.
Get your parts and let's do a wrench and wheel weekend.
Talk about a coincidence. One of the guys on my mai route has been talking with me about running the Magruder trail this some time this summer. Taking off from his place on Panther Creek road, doing a day trip over, spend the night, then come back the next day.
