I am not an engineer but this question has been niggling at me. When are those slipover (and maybe a set screw) type oil filter coolers a good thing? I am not even remotely curious about it for the TJ. With the straight 6, there is ample cooling. Just browsing the interwebs and saw them.
So...
At what point do those stop assisting in cooling and start withholding heat in? If ever. Assume a good fit, but not too snug, even though most are a set size and for a few different diameter filters. No paint, no anodizing, just plain aluminum for the finned "cooler." No thermal transfer compound, just surface to surface contact. What kind of heat transfer can you expect to make it worthwhile? Any, or are you just making the situation worse, by adding a "jacket" around the filter?
So...
