New Tool Day
Thats a cool socket. But driveshaft bolts are 8mm 12pt aren't they
That was provided simply as an example of the type of socket. I have no idea what size/head type he needs, as not enough information was presented.
Reactions: lBasket
I’m not a mechanic so I’m not sure what tool to search for so I’ll ask here. I’m trying to find a ratchet or something to remove driveshaft strap bolt nuts that face the pinion. I have to use the open end of a wrench and that sucks. Trying to chase down a problem that might have me remove the driveshaft over and over and future maintenance.
My ratcheting wrench’s are too wide to fit all the way down on the nut. Wide around the ratcheting part not wide as in needing a skinny wrench.
Hopefully this question is clearer than mud. 🤣
Not bad but the bolt might be too long. I have an angled adapter but it isn’t enough angle.
Picked up a set of spring compressors today. And yep Harbor freight :ROFLMAO:
May not need them, but I would rather have them.
I used my HF spring compressors for the first time about two weeks ago. Hell, they've only been sitting in my toolbox for four years. But hey, when you need 'em, you need 'em! I was surprised to find that they had a simple little retaining mechanism that is designed to keep the clamps from slipping and potentially flying off. Super simple design, and it seems like a viable solution to a potentially scary situation.
*(I worked at a brake and suspension shop in my youth, and my boss was installing big-block coils into a small-block '67 Camaro. Spring compressor slipped, and the coil went flying past my head, mere inches away. Scared the s#*t out of both of us!)
New use of an old tool, made a mount for my portaband that slides into my welding table. Hindsight being what it is, now I get to modify the mount so it’s level with the rest of the table for cutting longer pieces, will be easy to do though. This setup is now one of my most used fab tools. Should have made one years ago.
I like having left and right saws. Lots of flexibility. Especially when you're 40ft up hanging off a truss trimming 24" rafter tails and outlooks. Picking the saw that puts the saw body closer to you vs hanging in space is very nice.
-Mac
Reactions: ColoJeep
-Mac
Years ago I worked at a carpentry shop , and bought a magnesium worm drive Skilsaw to replace my Aluminum version . It was 2 lbs. lighter but it felt like it weighed nothing at the end of a long day. I learned how valuable it is to have good tools ! Trimming rafter tails sucks , anything you can do to make it better is worth it !
Swing through the Home Depot parking lot with cash in hand is the easiest way to get work done ;)
