I'm building the jeep mainly for cruising offroad and doing small jumps, not much rock crawling is planned at all
FYI this is my DD and I have cast outer knuckles, so i will not be doing any impressive jumps, mostly high speed cruising offroad and hitting bumps
Running 33's, plan to get 35's later
So with your anticipated usage as described above, why are you doing any of the stuff you are doing? Trusses, long arms, why?
You state a bunch of theoretical advantages connected to your mods. But those mods will not solve any problem that you've stated or any problem that might result from your intended usage.
The most likely result of the mods you seem intent on doing is to fuck up your suspension and add a bunch of unsprung weight that provides no benefit within the scope of your intended usage.
If you are not just here to troll, spend some time reading the many many threads on suspension, what works, what doesn't, and why. You keep saying you want to learn but seem resistant to the advice offered. Without knowing what problem you need solved, how can any advice be properly targeted?
My favorite question: what problem are we trying to solve?
