Multifunction switch
JGuevaSkye
St. Petersburg
I drive an 04 tj and the other day I tried to use my left turn signal and made a buzzing sound. Then when I turned on the headlights the left turn signal is constantly illuminated on the cluster. When driving on the highway every mile it starts beeping. If I hit the right turn signal it stops the beeping.
Does this sound like a bad multifunction switch to you?
Not sure about the buzz but I’d start by replacing the burnt out bulbs. Left front or rear bulb burnt out is usually a sign of the inside turn signal light lit. Last resort is the multi function switch or look for charred wires at the plug.
Welcome
Yes, the MFS can cause those issues, among other things.
I would also check the grounds near the headlights.
