P
The very easy way to work through the problem is just turn right a small amount to let the left side drop and then quickly turn left and get back into it.
What's going on that's making that front driver tire go up so much that would be eliminated if he straightened up? I can't see enough of the driver front tire to see how much his uptravel is limited.
I hatehow painfulfacebookmakes it to share thingsin general.
Watch the video and the correlation between the left lift and steering angle. You can clearly define that turning right lowers the left side, turning left raises it.I've experienced the left front lift but I've never tried turning right to counter it because in the situations I've had it, that would make the right side climb even faster. Not arguing against it, that's just why I never tried it. Guess I have something up my sleeve for next time.
Torque and resistance, nothing more. Also why there is a pretty cool way to combat the overall effect by using a reversed rotation rear output on a special transfer case.I also haven't really wrapped my mind around the mechanics of it. I was thinking the axles vs chassis reaction to driveshaft torque but the times I had it were with an open front diff, which with a wheel in the air shouldn't be able to offer any resistance for the torque to act against.
Yes, no, maybe, depends on what the other tires are doing. But no, you aren't really turning, you are just turning the steering wheel. You can see that the right front only has to turn a couple of inches to have a dramatic effect on how much the left lifts.Does one drive forward in between turns or not?
Little bits of momentum, a feel for what it is doing, and the awareness that just a tiny bit of right or just lowering the force on the right front by easing the steering wheel to the right a small bit all helps to learn what the rig can do and how to stay out of trouble. Myself and a fair number of the folks I wheel with wouldn't even slow down much through that spot in the video. As soon as the left started up, we'd ease back right until it dropped, back left and drive right through it.I haven’t tried this, but it seems like turning the wheel back left without moving forward, would just put you back where you were.
Nothing to do with uptravel. The lift is caused by too much resistance at the right front tire. It can be climbing something pretty steep or what we run into more often is the side of the tire against a flat face of a rock or similar. It is torque transfer to the chassis from the drivetrain that cause the left side to lift. If you can reduce the resistance at the right front, the left will come right down as you can see in the video.
So, many times when I’m wheelin or spotting someone I just straighten up or tell them too. Then it goes right up no problem. Same idea? Torque resistance reduced?
Not always, but it is also very common to lift the left front just going straight up a climb when the right front meets resistance. A way to visualize the forces is to contemplate a Jeep hanging straight up and down fully suspended by a winch cable from the front bumper. You could walk up to it and rotate it around the cable easily with one hand. Same rig sitting flat on level ground on the tires and you'd be hard pressed to dislocate one side more than an inch or so lifting with one hand in the middle of it.I also haven't really wrapped my mind around the mechanics of it.
And then it turns out that once @PNW_LJ graciously posted up the video so everyone could actually see it, its a shitty vertical video that's so far away that its hard to make out what's going on anyway! With that said, that situation would scare the crap out of me!
Sometimes the message is far more important than the messenger. This is one of those times.
As the chassis moves further from flat in the front, the less force it takes to rotate it.
All three of my examples were with the right rear tire in a hole with an abundance of grip.
Why is there always a hole for the right rear to drop into?
in my specific examples, bad line selection as I had figured out getting my front axle to follow my chosen line but not so good with the rear. When follow-up attempts were successful, they involved staying out of the hole. I haven't had this happen in a while because I intentionally avoid putting specifically my right rear tire in a hole, moreso than any of the others. I'm certain at some point I'll find a scenario where it's unavoidable though, and before this thread I'd probably have ended up winching through after a couple of failed attempts, but now I have a new tool in my belt.
