Fair enough. Just throwing out the suggestion because it seems like the number of people who have good reports about Savvy these days is approaching negative numbers.
Fair enough. Just throwing out the suggestion because it seems like the number of people who have good reports about Savvy these YEARS is approaching negative numbers.
FIFY and it's only going to get worse since they're changing it up.
Only the product availability, shipping and the ruined bumpers. The midarm appears to be unchanged from the original design.
Which doesn't seem to matter much if you can't get the parts to use it.![]()
Didn't they also go to the narrow 2" JJ that isn't really the same joint
Not on the midarm
Just the normal control arms? That joint is just a rubber bushing with the ball in it (not a rubber bushing expert), not the same polyurethane race design
FIFY
Are there?
I just looked. The mid-arm is stil JJ's but the short arm versions have a RK joint at one end.
Crafted from solid 7075 aluminum round bar, these control arms are far stronger and more resilient than competitor offerings. The lower control arms feature a 1.25” shank joint for unmatched strength and are equipped with a RockJock “Narrow” Housing Johnny Joint at the axle side, allowing maximum articulation and off-road performance. The frame-side uses the RK Adventure Series Joint, reducing noise, vibration, and harshness (NVH) while enhancing drivability and minimizing maintenance. The front upper control arms incorporate a heavy-duty steel fork at the axle end, utilizing the factory-installed bushing for a seamless fit. Meanwhile, the frame-side also features a RockJock “Narrow” Housing Johnny Joint, ensuring improved flexibility and articulation for the toughest trails. The total max misalignment has been increased from 60 degrees to 75 degrees with these updated assemblies.
RockJock is old Currie and not Rock Krawler![]()
That's dumb!
