Hard top to header issues
CJK440
Conn
I have an 03 with an early vented top. I noticed my hard top leaked between it and the header last winter while the soft top did not. I started the swap today and noticed the soft top door surrounds have a soft foam piece that surrounds the pilot wedge that mates into the plastic under the header seal. The hard top had some old crusty foam residue that sat in a stepped area which is now removed. I outlined the stepped area that had foam.
For the life of me I cant find any info on foam pieces for the TJ hard top other than the top-to-tub camper seal. Is there supposed to be foam on the front of the hard top? Is it available or just make your own?
Reactions: chili_pepper
This view may make a little more sense. I assume the header rubber will contact the top north of that horizontal step, but below it and around the alignment block is about 1/8" recessed. I didn't mount the top to check but assume there will be a gap between the top and that plastic track the alignment block fits into. This makes for a gap in the surface where the door seal touches which is right where the water comes in.
Its a factory early top, with a pentastar on the back glass.
Without any further info I'll make up some L shaped adhesive foam pads to close that gap but TJ's aren't a rare vehicle, if there is supposed to be foam pads here I would imagine I would have found something on the net about them, replacement foam, youtube video, forum posts but all I see is just JK foam. Are they called something else?
Header seal
Yes, there are supposed to be shaped foam pieces at that location on both sides, without them you will likely experience a severe water leak (ask me how I know :)). As far as I know, no one supplies them with the hardtop seal kits or as a separate item. Not even sure if Mopar lists them as a purchasable part. I am in the process of rehabbing my LJ's hardtop and removed what was left of mine. I created a CAD drawing of the profile of the foam piece, figured I'll be cutting my own to replace them.
Yours may be a different shape.
Reactions: Exm38a1er
Thanks for confirming I am not crazy. I have some foam from the center of a pickup 3rd brake light that should work good. I will employ CAD also (Cardboard assisted design).
So strange that these aren't reproduced.
Looks like what you sketched looks different than what I would need. I assume an LJ hard top would have a front section like a later non vented TJ top. Perhaps there lies the difference between my early top.
My passenger side was missing completely, leaving an approx. 1/4" gap between the top and header not covered by the door seal. When it rained, the water literally pissed through the gap and directly into the footwell below. Thankfully Jeep tubs have drain plugs. (y)
i’ve replaced the cowl, header and both door seals with oem mopar seals a still have a substantial leak on the passenger side where the front edge of hard door meets windshield frame and hardtop. have never had these foam pieces since i got the jeep nor have i ever seen them in a parts diagram. maybe this is the missing piece of the puzzle. smdh!
I know exactly what you mean. If you are missing these on your hardtop, they will make a difference. If you plan on making them, it's okay if the foam is a bit on the thick side.
But even with the foam, I still suffer from this. Can't seem to find a decent replacement door seal anywhere. On #3 now in 12 months, they all seem to be a bit shite.
Reactions: txbemis69
oem hard door seals were hard to find and the windshield header seal was on back order for over six months. mopar parts website kept telling me to not cancel my order that they were being made by the manufacturer. almost gave up on it. i’d like to see detailed pictures of your foam pieces before and after install. that would give me something to go on.
I'm interested. @chili_pepper, do you have any files you could share, or would it just be easier for me to buy some adhesive foam and trim myself?
Related: I was just wondering about this recently. On my 97 SE, I have some OEM rubber (not foam) pieces that insert here:
When in place, thy create a flat surface, which my soft top slides up against. (Sorry no pics; away from TJ at the moment.)
When mounting my hard top, I noticed that this part of the hard top (pic blow) was pressing against the rubber pads, preventing a proper seal with the windshield header. So, I removed the rubber pads, so that this part of the hard top could slide in.
Anyone else toggle between soft top and hard top and notice the same?
I missed the followup post to mine from @txbemis69 from months ago. My hardtop is still in the repair and refinish stage so I haven't gotten around to making these pieces yet, but I can make a PDF or DXF file available of what I plan to use.
Reactions: SSTJ
My hardtop has/had foam seals in this area, without these my top leaked badly.
I've attached a 1:1 PDF print file of a CAD profile I developed for this corner seal on my LJ's hardtop.
Edit: Updated the PDF to include a 1" long reference line to ensure proper printing for scale.
Anyone know how thick the OEM foam is? I'll order some soon.
I was figuring on using 1/4" thick foam to cut my pieces from, based on the gap measured with the top installed. I wouldn't imagine being thicker could hurt.
Reactions: SSTJ
