Grease recommendation
Speaking of grease.. you guys recommend any particular gun? The last 3 grease guns I bought were POS's.. is there one out there that doesn't leak all over the place when you're not using it? I have to keep mine wrapped in fuel spill pads or there will be one helluva mess.
Thank you! I like trying new greases out on things, so I'll give that one a shot on some joints that I have to install in the near future.
I've been using two different greases from Mystik on various grease-needing dinguses - JT-6 No.22 and JT-6 No. 2 Hi-Temp - and although I really like them, they seem to separate quickly no matter what I do. I had such a problem with it that I made myself a grease-storage area at work, and started going through an arcane ritual every time I used a grease gun: clean gun, depressurize, clean gun again, store horizontally on clean paper towel. All of the unused tubes are upright and they never get moved around, and I date them so that I know when they came in and when they need to be used. The temperature of the storage area is always around 65°. Results: they bleed just as quickly as they did before...although not nearly as bad as the NLGI 00 that I don't get to use as often as I would like.
There was a thread on POR about greases in grease guns doing that and several reported that the magical Green Grease was immune. I bought some with the recommended grease gun and in about 2 months, had the same mess that I get out of all the rest of the guns that I store grease in.
When taking on a new to me jeep with unknown history do you flush out grease-able joints (u, ball, chassis etc) with new product or just "top off" what is already there?
Is there one grease that is good for everything on the jeep?
I bought a Valvoline molly grease for suspension and also used it on the driveline and suspension. I was disapointed as I believe it washed out quick from mud and watercrossing.
I was thinking of something like a tacky marine grease.
Is there somthing water resistant that would be good for everything on the jeep?
Reactions: freedom_in_4low
It depends on your location and if there's any mods on your Jeep that require special grease. If I was limited to one tube of grease on a stock Jeep, I'd go with Amsoil Marine.
Reactions: Muddyjeep276
Jerry,
Are you still using Lucas Red 'N Tacky in your u-joints? Any complaints?
Thanks!
James
Red and Tacky is normally my go to and still is at my work. Been running Redline CV2 in everything now for a while to see how it works.
