Gerry Can Mounts?
Babygools99
Conroe, TX, United States
So i have the Smittybilt Xrc rear bumper with the tire carrier, and i was wondering what gerry can mounting options work well. I've seen the rockhard 4x4 mounts, and it looks like it would work with my setup, but i'm not 100% sure. Had anyone tried this, if not, what mounts are you guys running?
Sent from my SAMSUNG-SM-G930A using Tapatalk
I have a new mount from Rock Hard, it will fit if the tubing is the same size (if the mounting is the same), I did not use it for my jeep (back injury too much to lift) I can E-mail a pic & size of tubing if needed; donelec@sti.net.
I have Rockhard 4x4 can mounts:
As far as lifting is concerned: My water can has a bung for a spigot so there is no need to remove the can. For gasoline I use a "super siphon" which allows me to transfer fuel to the gas tank without removing the can.
See: https://www.amazon.com/dp/B000ZOT39A/?tag=wranglerorg-20
See also, https://www.amazon.com/dp/B00MVAIL76/?tag=wranglerorg-20
Reactions: Babygools99
The Rock Hard mounts are great. I got two old ones from my father and they clamp onto my tire carrier (also made from 2”x2” square tube) without a problem.
That's a smart idea!
