No. He still wants 488, even for cruising at 75mph at 3krpm.
Do you remember what RPM 4.56 would be turning at 75mph? Was it very significant or no?
Good to know. Still adjusting to mine and wasn't sure if I overgeared it. 3.07 to 4.88 is an entirely different vehicle.A 33" tire is going to have an effective rolling diameter of about 32"
NV3550/32"/4.56=2801rpm @ 75mph
NV3550/32"/4.88=2998rpm @ 75mph
I daily drove 33s/488 for many years over 100k miles and never once wanted less gear.
This is very will trodden territory. Historically, people have been undergeated for several dumb reasons that never seem to go away.
Do you think difference between an A/T less aggressive/ lighter weight tire and an M/T more aggressive/ heavier weight tire would justify 4.56? Or are they pretty well a useless gear ratio?
I've never understood why folks who own the Swiss army knife of vehicles are automatically lumped into the category of being ill prepared for emergencies. If you know you have something that is oddball, different, difficult to source, then buy some fucking spare parts.My point is that you still have 27 spline outers and the weak link will lie in the joint (as he says). The inner splines are rarely the issue, and certainly won't be if the OP is running 33's and only doing things possible with a single locker. Keeping a 27 spline locker/carrier allows the use of stock shafts as emergency backups if needed. You can find 27 spline Dana 30 shafts in any junkyard in a pinch.
My 1st gear is 4.46:1 with 5.13s and 35s and it is as useful on pavement as the OEM 4.46:1 with 4.10s and 30.5s was.1st gear is pretty useless on pavement.
That's not a granny low. A granny low is 6.55:1 or 7.05:1.It's essentially a 4 speed with a granny low gear now.
Ok. All I'm saying is 1st is very low now, and I've pretty much abandoned its use for flat ground pavement driving unless I want to shift it before I move 5 feet.
Yep. I went 4.56 specifically for this and it's 2750 at 75mph. 3120 rpm at 85mph. My tires are 285/75R16 with an actual rolling diameter of 32.6". This size is also a pretty common actual diameter with most of the 33s for 15" rims.
During my time with 488/33s, I was routinely taking off in 1st and shifting a bit below 4krpm.
..... For me I wanted to keep the engine rpm under 3k at 75mph and get 4th gear up the curve at 50mph enough to hold gear on a steep section of I70 - which it did going from 2113 to 2350,
If we are thinking of the same section of 70 at the tunnels, I was frequently able to hang on to 53-54mph at the top of the hill with my deeper gearing. And that old combination did better in that spot than what I have going on now.
Why do you want your cruise RPM so close to peak torque? This is not common practice. Down shifting should be expected for passing or very steep grades.
Because I want a keep that can start to get out of it's own way. Because some of us have figured out how to build a jeep that does not behave like a Jeep a thing because you don't understand.
