Engine swap comparison
You could rent a car in your area for $25 per day if it takes two weeks it would still be with in your $2500 budget to do it the right way.
Dennis Wells Machine Shop in Duncanville or Wayne Calvert Precision Engines in Denton are two machine shop that the AMC guys use in your area.
It is tempting to just do it quick but better to do it right and get another 300k out of the Jeep.
You were talking about a engine swap and that would take about a month if you did not run it to any issues ( ECU to swapped engine) which is always going to happen plus the tow to the muffler shop to get the exhaust system made.
That said SCB with carb and Turbo 350 would be the easiest but then you are still dealing with the wiring for all your systems.
This is a fair point, but no one likes to rent cars to college kids. The plan was to get her sorted for atleast the next 5years at which point a swap may become feasible
It is worth noting I wound up doing rod bearings and getting a press to (was probably past time for that), so all told I'm in the hole closer to $750 for this escapade.
