If sticking with the i6 I'm not sure if stroking it is a great idea. Better rod geometry with the stock crank and it will need to spin a bit higher to hit your target.
Yeah I thought about that("cheaper too")These AMC i6s get bad cam harmonics at around 5800 ! Unless you Rev past that, then your good but I'll keep it at/below 5600 or so,Piston speed shouldnt be bad either at that rpm.
I've been to 6k Rpm before and kept it there,I wonder if that's why my cam bearings are chewed? but even with my stock head it did "fine" and after cam swapping it I saw 0 damage it wasnt until i did the head with the Ls valvetrain with the unbelievably stiff ass valve springs....But I digress
