Passenger side sway bar mount was running on the spring occasionally, but couldn't move forward due to the trackbar. Raised it up a little and rotated the bolt 90°.
Made it out on the trail for the weekend. Managed to bend the tie rod. I need to stop using it as a feeler. Conveniently it straightens easily. Hopefully I can get a replacement next time Blaine is doing a batch. I may try 7075 as an intermediary until then, just might need to dimple my diff cover a little more for clearance at full lock.
My math has my current setup good for 900 lbs.
1.5" 7075 should be around 1800 lbs.
Depending on the heat treat, solid 1 1/4" 4340 could be up to 2600 lbs.
