Brake lights not working
98 Black Bart
Birmingham Al;abama
My brake lights are out checked the fuse Behind the glove Box good. Changed out the switch at the Pedal it's all the same no lights. stumped anyone got any help?
Change out the fuse just to be safe. Check the grounds on the lights. They use the mounting bolts that connect it to the tub. It's odd both them went out. It really points to fuse or switch. 🤷‍♂️
Its the third brake light working?
Have you checked the taillights themselves?
Since the taillights are grounded to the body, often times if you have a rusted body or taillight guards, the ground points for the taillights won't be good, and then the brake lights won't work. Although if that's the case, usually nothing else will work either (i.e. turn signals and parking lights), but it's still worth checking.
The other obvious thing to check (and PLEASE do this) is the brake light bulbs themselves.
I find in situations like this, usually it's the very simplest answer that ends up being it. Occam's Razor basically.
