Bestop fit issues
red02tj
TJ Expert
Atlanta
I got a new top during the Bestop spring sale but it’s been mostly down since the weather has been so nice and it needs a good few hot days to stretch out, so I waited to see if it would stretch out.
The alignment on the top is off center, and pulling from the back corners. This is the 3rd top I’ve had on the frame, my second replace a top, never had any other issues. Opened a warranty claim and Bestop is saying my rear bow is walled out and they only support their bow straps, which is allowing the top to rotate.
Before I got back and push, anyone have any insights?
@Crystal@Bestop this is what we were PMing about.
Do you have the plastic corner pieces? I know when I don't install mine the top is loose in the back around the windows.
Yep. Have the tail gate clips and the plastics on the bottom of the corner that wraps around
you are missing the corner stiffeners, that's a big part of your problem.
it’s a full replace a top, I’ve got all the same parts my other tops have had. I’ve only seen plastics insert in the corner fabric verticals section on MasterTops
Reactions: TheBoogieman
I was referring to the stiffeners. You should be able to get them from Bestop. They would help with your top sagging.
None of my previous bestops have had those. My issue is less saggging and more the top isn’t square, so when it’s latched at the header, it’s rotating 10-15*
If you want to try the stiffeners let me know, I think i have a couple of sets. Your welcome to one if you want a set.
Yep. 2+hr wait earlier this week to speak with someone, and today they say their phones are down because they’re too busy to answer. And I’ve never gotten a response to my emails.
What about the Bestop rep on here?
Hi there - @red02tj and @TheBoogieman
We sincerely apologize for the inconvenience during our Customer Service peak season. This year has brought significantly higher-than-usual email and call volumes, which unfortunately has led to delayed email responses and longer hold times.
Our team is working hard to get back to everyone as quickly as possible, and emails are answered in the order they’re received. To help avoid further delays, we kindly ask that customers send only one email per inquiry.
We know the hold times can be frustrating — but calling in remains the fastest way to connect with a rep directly. Thanks for your patience and understanding while we work through this busy season.
You will get an email response from the team, again, my apologies for the inconvenience and delay.
~Crystal@Bestop
www.bestop.com
3 weeks…and I finally got approved for a rear window replacement, under the current assumption it’s misaligned which is causing the tight fit/rotation.
To be continued.
Warranty replacement has still not shipped. Current wait time is 190-240 minutes.
@Crystal@Bestop at what point do I just dispute the charge with my CC and order from someone else.
Wait time for emails is probably 5-7 days. I would've disputed it and got a refund in the 3 weeks you waited to get approved. I have zero patience for bad customer service.
Reactions: John Cooper
hah...they're in the convertible top business and complaining about peak call volume / seasonal demand.
pretty sure summer comes every year :)
those call/email response times are atrocious.
