Axle assembly options
Thats crazy expensive. I dropped 16k for Currie axles front and rear w/ ARB lockers and a few other add items.
yeah it is. believe me I am well aware. its not a new thing. this place is stupid expensive for everything.
Aside from that how do you like the curries? I'm leaning that direction.
Overall I'm happy, I wish they would have had the 60 option upfront that they do now. I don't like that I had to keep the 30 outers. Now they offer JK/TJ HP60 front and rear.
Couldn't you have swapped out for 44 parts up front?
@ChadH . Have you been looking at axles over here on FB? You might find a set. Just thinking.
Not recently, I have in the past summer though and didnt find anything. My thought was possibly replace the axles in the LJ, then put those axles under the TJ. I'm pretty confident at this point that the TJ's rear axle got warped with the original damage form the local shop that 'forgot' to put gear oil back in the rear diff and thats the source of the continual noise and leakage despite a rebuild.
Both of them say "Fusion Heavy Duty High Pinion 44 C-to-C Axle Housing" Maybe give them a call. They might be running the JK housing on the TJ anyhow. Its the same price on both.
Nah. only on the "JK upgrade" do they have JK housing and JK outers. But the standard 44's retain factory outer knuckles, brakes, etc.... The upgraded housings are JK width but I need to stick with stock TJ width so unfortunately that doesnt look like it's an option.
With the limitations, I think I would be locating a set of Rubicon axles somewhere. Making a road trip to get them and rent a self storage garage and swap them.
If I found them at a junk yard I would even be inclined to make a deal to hire the yard dudes to do the work and priced based on leaving a good set of resellable axles behind. The entire road trip swap vacation would be thousands less than your quote. Inconvenient, sure. Convenient, moreso than 10k.
Reactions: Tob
That would be awesome. With the current situations at work, not an option unless I could find them within a 4 hour distance.
Reactions: DuckNut
fwiw, I purchased a Pro Rock 44 front housing on Black Friday since something is wrong with my front Rubi housing.
- Stock TJ width
- 3” tubes
- .5” wall thickness.
If all goes well, I’ll be able to re-use my Yukon big hub kit, BMB BBK, Eaton locker, and axle shafts.
Reactions: JMT and ChadH
For what it's worth, you could carry an axle into a basement with the help of one other person. They really aren't that heavy. I am work8ng on my own regear after a $6k quote.
Reactions: lBasket
The axles have already been rebuilt - but they have continuing problems. I'm thinking the housing is warped.
